Versant 80 no cyan
  • alextech
    • Apr 2023
    • 24
    Versant 80 no cyan
    hi there
    I have a Box where Cyan is Missing. When i came to the Machine, i noticed that some of the Drumsurface was gone and refound it on the Developers magnetic roller.
    The Developer and Drums are replaced now, but it still not prints Cyan.
    The Strange thing is, that i have no Errorcodes at all, machine thinks everything is as it should.
    Any sugesstions where to start?
    Here some Testprints:
    From the Bad Machine (Cyan only Test):
    From a good Machine (Cyan only Test):
    CMYK Pattern from the Bad Machine:
    I have not checked the Drum/Developer gears from the backside yet, but i think its the direction to go because when i print the Testprint, where cyan should be its completly white, so i guess its not a HV Story.
    Maybe someone knows that Picture and can save me a lot of time
    alex
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Versant 80 no cyan
    make a mark on the drum and developer roller. if the mark doesn't move you have no drive. If it does move I would like at the laser or halftone-pwb
    • alextech
      • Apr 2023
      • 24
      • adriansto
        • 2387
        This is what manual says:
        • 091-929: Drum C CRUM Not Position.
          No mention about MCU. Simply replace the drum if everything you checked was ok.
        • alextech
          • Apr 2023
          • 24
          First of all, thanks for your reply adriansto!
          Did that serval times. Even Swaped inside same Machine. With other Colors the Drum works perfectly.
          I have this in my Man:
          The Problem is, that you not really get easy to the connectors at the rear of the Drum AND in the consumables the Drum shows up with its remaining lifetime (tested 3 drums and the value changes..).
          The Error disapered now also, so i think its the wrong direction.
          Did some more searching and printing, after some time all cyan was gone from the testprints:
          Then i tested if the Tonerdispenser is working:
          I put a tape on it, and it was full of toner. So, thats okey.
          Next i opend the Developerhousing and saw that it was almost empty. Replaced (swaped) the Developer from a working V80
          and did again a Testprint:
          Now the Page is covered with cyan exept there where it should be, there its clean and white.
          Very, Very Strange.
          Brings me back somehow the the PCBs i guess.
          • adriansto
            • 2387
            This is pdf service manual from 2014 year. On latest edoc service manual dont mention MCU.
            Tale a look at HVPS for drum charge, bias for dev assy, wires and contacts and ROS.
            • xcopytech
              • Aug 2006
              • 1794
              Check developer contact in machine.
              You do not have developer bias
              • alextech
                • Apr 2023
                • 24
                Yeah. Dont saw any
                Will start at the Contacts, good idea!
                keep you updated!
                • alextech
                  • Apr 2023
                  • 24
                  Here a update:
                  Machine is still down. I replaced the complete Dev Housing and filled with new Dev.
                  Controlled the Contacts, they look good. Dev is also turning...
                  Any Idea where to look next?
                  • adriansto
                    • 2387
                    Read about xerographic process works.
                    • alextech
                      • Apr 2023
                      • 24
                      While you wrote the replay i was swapping the dev bias hvps. C/K.
                      Finaly the Sheet is covered with K and not C anymore and K is gone.
                      Searching now for some spares to replace the defective hvps, i think i have some left from a 700i, they should work.
                      But thanks for the asskick ;-)
                      • alextech
                        • Apr 2023
                        • 24
                        Love to ask stupid questions as you know:
                        Where you got that picture from? Was searching my man up and down to know which one is k and C.
                        • adriansto
                          • 2387
                          From my pws edoc. There is a section with machine training.
                          • alextech
                            • Apr 2023
                            • 24
