Re-load System software for Fiery EX-i on Xerox Primelink C9065
  • green4go
    • Jan 2022
    • 49
    Hello everyone
    This Primelink 9065 with a EX-i Fiery take about 5 minutes to connect to CWS or to the print driver first thing in the morning. You can still get to the web-interface, but takes a bit longer to connect to CWS. I trouble shot this by taking the Fiery off the network and crossed-over. This problem still existed the same way.
    I have the System software for the Fiery on a flash drive. but I can't find any installation instruction for this Fiery model.
    Does anyone have the instruction on how to do the install?
    Thanks in Advance
  • xcopytech
    • Aug 2006
    • 1783
    Re: Re-load System software for Fiery EX-i on Xerox Primelink C9065
    Power off fiery.
    Remove cables from fiery except power cable.
    Set service switch 1 to ON and leave 2 to off.
    Attach usb to any port.
    Power on fiery.
    After some time small led display will start to count
    When fiery go off remove usb, reconnect cables, set both service switches to off.
    Power on machine and fiery
    • green4go
      • Jan 2022
      • 49
      Thank You for the help
