Xerox licensing for 6204 is not available
+ More Options
Posts
  • over
    • May 2023
    • 1
    #16
    Re: Xerox licensing for 6204 is not available
    Originally posted by xcopytech
    I try it right now and it works.
    Try to clone hdd with ghost4unix
    Hello!
    Is it works (xrxgsn) with accxes HFT controllers? serial number prefix PUN. ZDC-1 product identifier at case.
    I used Synergix scanner with Accxes HFT controller for scanning. After russian rocket attacks in my office controller fell down on the floor and HDD was broken.
    I reinstall system at new HDD, but i cant activate scan to net cupon.
    any ideas how to make it work?
    thanks a lot for ideas..
    • aneudimadera
      • May 2014
      • 30
      #17
      Originally posted by Tecnico_Xerox
      You will have something new with the process?, it works for you?.
      Greetings
      Hello, the cloning procedure was successful with ghost4unix, but here are many customers with problems because they have controllers with damaged HDD and need to replace them.
      I really don't know why Xerox is doing this because that printer is one of the most reliable and stable machines they have. I have more than 50 customers here in DR and the printers are in perfect working conditions.
      Enviado desde mi STK-LX3 mediante Tapatalk
      • tcal123
        • Jul 2023
        • 1
        #18
        Hi there! Im from Bulgaria. Our company have Xerox 6204 wide format, and from one month the device can only to print, we cant make scans, before that we can make it. Can you please help me to resolve this problem some how? best regards!
        • xcopytech
          • Aug 2006
          • 1792
          #19
          If you have an old enablement plot files it is possible to create new file from old one.
          • xenalit
            • Sep 2023
            • 8
            #20
            Hello! I am an authorized Xerox engineer. I was surprised to find a closed license activation portal. The upward appeal was unsuccessful, the equipment was removed from support. Do you think a clone of a disk from the same machine will work on a different controller? It's a shame that good technology becomes just a piece of iron...
            • Dmitry77
              • May 2023
              • 4
              #21
              Hello.I have an Xerox WF 6204 freeflow Optiplex 780 controller, I need to restore the system on it, but the licenses can no longer be activated. Perhaps someone has a working image hdd of the Optiplex780 disk, thank you in advance.
              Also, when installing the system again, the web interface does not work, jbossrunning does not start, what could be wrong?
              • Tecnico_Xerox
                • Jan 2019
                • 54
                #22
                Hello xcopytech, I wanted to know if I can make some technical questions, it is with respect to Xerox 6204 plotters and the problem of licenses on servers. I have done some tests and experiments but without good results, so I wanted to rely on your experience and see if there is any solution to the problem. Thank you very much and I look forward to your answer. Best regards.
                • xenalit
                  • Sep 2023
                  • 8
                  #23
                  Try installing a new Accxess after installation on the controller to which the printer, scanner and UI are connected.
                  But this makes little sense, because... no licenses. I have no experience with images from other controllers yet.
                  • xenalit
                    • Sep 2023
                    • 8
                    #24
                    What exactly did you try? Have you tried installing clones of disks from other controllers?
                    • aneudimadera
                      • May 2014
                      • 30
                      #25
                      Can you please explain that procedure? I was looking some files but I cant figure out what to change.
