Re: AltBoot problem - Unable to decrypt DLM
Hi!
Is there a working solution for "Unable to decrypt .dlm" Perform Special altboot?
Have same trouble with dead Hdd- when replacing it with blank printer says unable to decrypt .dlm Perform special altboot.
Printer is Xerox Altalink C8055
Original HDD is totally dead and we cant copy even partitions.
Service manual says:
Be sure to install a System Disk Drive from Xerox Distribution; the use of any other hard drive will prevent the machine from booting. Do not reuse a hard drive from any other machine.
Figure 3 Installing the Disk Drive in the HDD chassis
3.Perform Regular AltBoot (GP 9) after reassembling the machine.
Ordered oem Xerox Disk: 121E28133 - came blank WD blue 500gb, with no Xerox stickers, same problem.
Local Xerox distributor says there are no special altboot proceedure. Use blank Disk as on older Workcentre 7855.
Then they said to copy disk from working same model machine- tried- doesnt work, same problem.
SD is not corrupted. We inserted blank HDD in working machine and tried to altboot- same problem- unable to decrypt .dlm.
We can Copy working hdd and insert in same machine from its copied and it works - I guess its encrypted to exact one machine or it just checks serial number on Hdd.
Any help appriciated.
Cant get those swup files anywhere- can try them if somebody sends me them.
Regards,
Karlis
Hi!
Regards,
Karlis
