img sd card of xerox altalink c8035 with zero billing
  • nibiru.nat
    • May 2023
    • 5
    Good afternoon, i really need an image for the WC Altalink C 8035 sd card, it constantly reboots. Altbооt does not help.
  • adriansto
    • 2387
    Re: img sd card of xerox altalink c8035 with zero billing
    Really need it?
    What is the code on the digit display?
    What is the size of .dlm file you use for altboot?
    • nibiru.nat
      • May 2023
      • 5
      on the display n ,after three reboots, this error hangs. The download reaches the point and everything breaks into a reboot.
      dlm size
      AltaLink_C8030_35_ALTBOOT_system-sw#10300101014010#ENG_MOD.DLM 487 655 kb
      • xcopytech
        • Aug 2006
        • 1794
        What kind of problem you had before altboot?
        Do you have full altboot dlm file about 500mb
        • nibiru.nat
          • May 2023
          • 5
          after exit non consumer mode
          • xcopytech
            • Aug 2006
            • 1794
            You had "machine in non customer" mode or you have it now after altboot
            • nibiru.nat
              • May 2023
              • 5
              before
              after changes nvm in the MFP, it should reboot and enter normal mode ,but no...
              • xcopytech
                • Aug 2006
                • 1794
                Altboot can not fix that problem.
                Now try with sd card image qnd with special altboot
                • nibiru.nat
                  • May 2023
                  • 5
                  this is not unfortunately
                  • adriansto
                    • 2387
                    There are two sd card size 4GB and 8GB. Do you check what size is your card and buy new sd card and reimage it.
