Xerox c560 banding
  • tortemedenjaci
    • May 2023
    • 1
    Xerox c560 banding
    Hi Guys,
    I hope you can help us with some useful information as I can see people trying to help which is amazing.
    We have very light bands across the whole page (from the left to the right, they are black), attached screen is showing print. This will happen only on the white part (unprinted area)
    Example is empty PDF file, coated 300gsm paper. But it will happen on any paper
    Where we have CMYK, it's absolutely fine, problem is only white area.
    Some useful information
    - Black drum is almost new
    - IBT film new
    - OEM toners
    - Fuser is almost new
    - Cable between Fiery and machine is connected properly
    - We have cleaned 2 BTR
    - Our contract ended with Xerox, so some things we need to sort in house
    I have found some old post here which is pretty similar, but suggested screen about NVM values seems identical.
    Miscellaneous Xerox 550 printing very light bands across SRA3 sheet even from blank/clear pdf (copytechnet.com)
    Do you have any idea what else we can look to sort the issue?
    Also, we have stopped machine before the paper came into fuser, it was all good (unless we don't see that dirty toner). Like it's fusing paper too much, but no matter on fiery/paper settings, it is same.
    Many thanks,
    Milos
