Blue background when copy and scan color xerox 7855
  • dacam20590
    • May 2019
    • 30
  • Mr_FixOK
    • Dec 2012
    • 25
    Re: Blue background when copy and scan color xerox 7855
    [ATTACH=CONFIG]58407[/ATTACH]
    Does it do this on internal prints as well? I do not see a white border around the print so that leads me to believe that it is not scanner induced. I would first try swapping the Cyan drum into another color slot and see if the issue follows it. Barring that I would examine the IBT after doing a stop print and see what is on the belt. It could be a first BTR issue as well, which would entail removing the belt material and cleaning the first BTR rollers. Good luck, hope you get it fixed.
    • shinchan
      • May 2011
      • 197
      turn on shadow suppresion during copy and scan color.
      IIRC it's under , Image quality>effects > shadow suppresion
      if you print the original file, the result is clear right no blue background?
