fault 042-317 xerox 700
  • sniper2g8
    • Jan 2013
    • 117
    [Error Code] fault 042-317 xerox 700
    I have xerox 700 color press anytime I on the machine it given error code. fault 042-317 xerox 700 please help
  • xcopytech
    • Aug 2006
    • 1794
    Re: fault 042-317 xerox 700
    AC unit fan
    • sniper2g8
      • Jan 2013
      • 117
      Originally posted by xcopytech
      AC unit fan
      Thanks for the quick responds I have changed the AC unit fan but I'm still receiving the error.
      • xcopytech
        • Aug 2006
        • 1794
        Check for 24V on J517 between pins 1 and 3 and for 3.3V between pin 2 and ground
        • sniper2g8
          • Jan 2013
          • 117
          should I check on the iot board or the power board, I will be glad if you can reply with pictures thanks
          • adriansto
            • 2392
            Also check missing connection on AC power supply
            • sniper2g8
              • Jan 2013
              • 117
              thank you for your help, I checkd and the AC fan cable was disconnected from the IOT board after connect the problem has been solved.
