Xerox Versant 80 error
  • otphas
    • Aug 2019
    • 127
    Hello ,
    we get error code 123-354 , we think that ESS board is damaged, is it have any chance to repair the board ?
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox Versant 80 error
    What is machine software version?
    • otphas
      • Aug 2019
      • 127
      Dont know , when we start the machine just 6 buttons on the display flashing 5 times and the machine restart .
      • xcopytech
        • Aug 2006
        • 1794
        Check fuses on lvps
        • otphas
          • Aug 2019
          • 127
          Fuses are ok.
          • xcopytech
            • Aug 2006
            • 1794
            Have you checked both lvps
            • otphas
              • Aug 2019
              • 127
              only 1
              • xcopytech
                • Aug 2006
                • 1794
                Check fuses on both lvps
                • azehnali
                  • Nov 2009
                  • 679
                  how did this problem happe?
                  • otphas
                    • Aug 2019
                    • 127
                    The customer connect the cable from display reversed in the machine.
                    • azehnali
                      • Nov 2009
                      • 679
                      then change the ees board
                      • otphas
                        • Aug 2019
                        • 127
                        Any chance to fix the board?
                        • xcopytech
                          • Aug 2006
                          • 1794
                          You first can check leds on ess pwb.
                          • WIWA
                            • Mar 2009
                            • 97
                            Originally posted by otphas
                            Hello ,
                            Fault means Panel System Fail, Check for 24VDC source on both places panel and ESS check for those surface mount fuses vin and vout if you are soldered skilled take out from an old scrab board same value fuse and replace it .
                            Hope this helps,
                            Wiwa 72 , Gonzos build V1.0
                            • Andru
                              • Sep 2024
                              • 1
                              I have the same problem. How did you solve yours?
