Versant 80
  • copytech,mike
    CopyTech,MIKE
    • Jun 2014
    • 255
    Versant 80
    Hi guys, I have a 061-310 code. First it was an 061-326 then it changed to a 310. I broke a connector on flat cable for laser yellow while checking the flat cables. (Now i know you gotta flip up the connector holder before pulling on flat cable). I have a new MCU Board coming. My guess is that its a bad flat cable connection. Any ideas? I think the laser unit is good. 310 code is for clapper 1. I think thats for laser unit 1 for mag/yellow? Ordered new MCU Board and a good used laser unit just in case. Pray for me!
  • WIWA
    • Mar 2009
    • 97
    Re: Versant 80
    Well , on my experiences with those models never replaced an MCU for laser codes , most has been laser related, flat cable related, or flat cable wrongly placed specially at laser side it's hard to place it properly because of space. The 061-310 fault refer to a Halftone (read/write problem) pwb and MCU . The 0 61-326 refer to MCU and ROS assy (laser unit) LDD Laser Diode. both rap refer to 24 volts check up tell you this because the code change so check 24 vdc on LVPS just in case after you replace the MCU.
    Hope this helps,
    Wiwa 72, Gonzos build v !.0
    • copytech,mike
      CopyTech,MIKE
      • Jun 2014
      • 255
      Re: Versant 80
      Hope this helps,
      I ordered a new halftone board and a new laser unit. I will get back to you after i replace. Thnaks.
      • copytech,mike
        CopyTech,MIKE
        • Jun 2014
        • 255
        Re: Versant 80
        New Halftone board installled and the 310 code is gone. Now back to 326 code. Im going after the Laser unit now.
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 255
          Re: Versant 80
          Hope this helps,
          Hi there, the new halftone did the trick. All 061 cods are now gone! Thanks for helping me on this. Take care.
