Phaser 7800 blue marks on paper
  • positiveg
    • Jun 2018
    • 299
    Hi guys, I hope all is well.
    I'm getting some weird marks on my prints. It's a cyan print. In the exact clsame area. Looks like it can be coming from some roller or so, but I'm not sure where. It definitely happening before the print fuse to the paper
    Take a look please and thanks and assist if you can would really appreciate. Thanks in advance.
    G
    Sent from my SM-G780G using Tapatalk
  • Techlife
    • Mar 2015
    • 27
    Re: Phaser 7800 blue marks on paper
    Cyan drum (or pcu, dont work on Xerox so dont know what they have)
    • positiveg
      • Jun 2018
      • 299
      I've installed a new cyanbdrum. Even switched around the drum to see if a different colour would show up
      • shinchan
        • May 2011
        • 194
        so what's the result?
        my first guess is also Cyan Drum. because the weird marking color is cyan...
        • positiveg
          • Jun 2018
          • 299
          Results were still the same.
          I've installed a new drum. Will try another drum.
          I dint even see marking in the cyan so could have said it's the cyan. But thanks will try again
          • xcopytech
            • Aug 2006
            • 1783
            What is distance between marks
            • positiveg
              • Jun 2018
              • 299
              Well I guess I didn't really change the cyan drum.
              I did so and guess at the marks disappeared.
              Firstly I switched the cyan and yellow drum and I saw the marks but in yellow. Now I'm changed the cyan drum no more marks. Thanks much. And the cyan I think was the newest drum I wondered how it got damaged?
