[Image Quality] Xerox B8075 - Right side dragging on Doc Feed copies
  • Devrookie
    • Jun 2023
    • 7
    Hello,
    I've been trying to figure out this issue for the past few days. On the image below, I keep getting this slight drag on the right side. It's more noticeable on the top right. Any suggestions to get this fix would be much help. Also, I've cleaned the rollers on the doc feeder.
  • xcopytech
    • Aug 2006
    • 1794
    Re: [Image Quality] Xerox B8075 - Right side dragging on Doc Feed copies
    Have you tried dc608
    • Tech-Yeah
      • Nov 2022
      • 8
      The DADF is not seating down on the glass properly. You can press down on the DADF and feed a document to verify. Most likely you have a broken hinge mount or cracked DADF frame.
      • Dech1
        Senior Engineer
        • Dec 2022
        • 62
        Replace your ADF Base frame..
        • johammer
          • Oct 2014
          • 13
          I realize I'm a bit late here but, the rear spring on the reading plate has been updated for this problem, making it a little less stiff. 607K30440 SPDH Distortion Spring Kit
