Versant 80 error code 099-382
  • irdicheku
    • Aug 2019
    • 17
    Anyone ever come across this fault code. Already change the fuser belt unit but still the same. Any help is appreciated. Thanks
    Sent from my EML-L29 using Tapatalk
  • adriansto
    • 2387
    Re: Versant 80 error code 099-382
    Wrong part was changed.
    this code means the Heat Pad side lamp is continuously on for more than the specified time during warmup of the Fusing Unit.
    • xcopytech
      • Aug 2006
      • 1794
      Replace AC fusing power supply
      • irdicheku
        • Aug 2019
        • 17
        Ok thanks for the feedback. At first I changed the lvps after I found that one of the connectors measured zero voltage. So kind of confusing for me. According to Edoc need to replace MCU as well, which is so expensive. I will try to change the AC first. Thanks again
        • irdicheku
          • Aug 2019
          • 17
          Change it already but the machine still exhibits the same code. So I guess my final try is the MCU. Or is there any other solutions.
          Sent from my SM-A536E using Tapatalk
          • adriansto
            • 2387
            Did you follow the exact procedure in edoc?
            There are many checks to be done before replacing pwbs.
            • irdicheku
              • Aug 2019
              • 17
              Pretty much everything I checked. Heat pad side lamp, thermistor, connectivity for MCU PWB J406 and it seems fine. And I change the MCU as well but it stills show the same error code. Now I'm not sure what else I can change. Any ideas or suggestions will be much appreciated. Thanks.
              • adriansto
                • 2387
                Try nvm init. Before do dc361 nvm backup.
                • WIWA
                  • Mar 2009
                  • 97
                  Well just in case run DC140 010-202/203 for thermistor , check the drawer electrical plug on both sides to verify if contacts are in good shape or any foreign material inside like a piece of paper. check the thermistor resistance at the closest to the sensor as well at the mcu just in case for an open circuit . in my experiences on those models too many nvm glitches. I had once a machine toner full reads with no toner on cartridges and drums 0 % making copies like charm and was solved just changing an nvm value .
                  Hop this Helps,
                  Wiwa 72 Gonzos build v.1.0
                  • irdicheku
                    • Aug 2019
                    • 17
                    Thanks brother. Your suggestion finally solve my issue. I never thought of it at first because if I initialize the IOT NVM I need to restore back all the NVMs for the impulse banding kit, 2nd btr etc, which is more than hundreds of NVM writing. This code they should just can be reset by a simple NVM writing instead of resetting all the important data. Thanks guys for all the feedback. [emoji482] [emoji122]
