versant V80 errorcode 012-264 then 012-243
  • garuda
    • 26
    it happened when paperjam, slide out the booklet drawer then 012-264.
    I removed the PL17.131 sensor, then 012-243.
    How to enter to CC mode for testing the knife home sensor.
    I bought the manual off "stoadis", book didn't mention keys to enter CC Mode.
    Anyhelp appreciated very much.
    Cheers
  • xcopytech
    • Aug 2006
    • 1794
    Re: versant V80 errorcode 012-264 then 012-243
    Section 6 of service manual
    On first page of this section there is procedure for entering is diagnostic mode.
    To find test code for finisher you need finisher service manual
    • adriansto
      • 2387
      Chapter6 from service manual tell you how to do this. DC 330 is the diagnostic routine for check the inputs and outputs. Pay attention when you use service manual. Bussines Ready Finisher have a separate service manual.
      1. Enter UI Diagnostic (CSE) Mode.
      2. Press the Machine Status button.
      3. Select the Tools tab.
      4. Under Features , scroll down to Maintenance / Diagnostics ... and select it.
      5. On the Maintenance / Diagnostics screen, press the Down Arrow, and then select IO Check .
      6. On the IO Check screen, select Component Control
