Issues With NFN-1 Internal Finisher Recognizing New Model Placement
  • chrisban35
    • Jan 2011
    • 199
    HELP! - I took the NFN-1 off of a VLC7030 and placed it on a ALC8055 machine. Of course, I turned the finisher over, removed the locking screw, made the size change and then used it on a different machine series, but I've done it in the past with success. The process I used the last time, is not working this time. So I need some extra help from people who have more experience with these finishers.
    I ran the forced_upgrade USB and used the swup.usb and swup_usb.C8045_55 files along with the original 100 version of SPAR hoping to reset everything and let the machine rediscover the finisher and flash it. But it successfully runs SPAR but does not show the finisher unit as an attached peripheral.
    I have all the other .dlm files but not sure which ones I would need to use to make this work. I'm hoping another tech out there has done a similar swap from one machine series to another with the NFN-1 Internal Finisher and can guide me through the proper steps.
    I also have the following:
    - diffDLMValidation.txt
    - 1057305v14.dlm
    - 417710v.dlm
    - Third Party Software SPAR - 729, 800, 842, 980, 993
    Thanks in advance for your help. My client desperately needs this done ASAP! So I hope someone out there can help me.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Issues With NFN-1 Internal Finisher Recognizing New Model Placement
    I think that finisher can only work on slow speed Altalink C8030 and C8035
