Xerox D125 error code 042-312
  • VINCENT23OMAN
    • May 2021
    • 14
    [Error Code] Xerox D125 error code 042-312
    hello and good day everyone, I just want to ask if anyone encountered and solve Xerox D125 error code 042-312
    I already check all the fuse in the IO board all are good and also replaced the duplex solenoid. The two fans at the back of the machine are also working. Can anyone give an idea about the error..
    Thank you
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox D125 error code 042-312
    Check or replace cleaner intake fan
    • VINCENT23OMAN
      • May 2021
      • 14
      Hello, is this the intake fan
      • xcopytech
        • Aug 2006
        • 1794
        No, check pl 3.1 in service manual
        • VINCENT23OMAN
          • May 2021
          • 14
          sorry to bother you but I dont have the manual of the machine. If you can send the image of the said intake fan maybe It will help me to locate it in the machine
          Thank you.
          PS.
          I dont have the manual because I am not a technician from the distributor. Im an in house tech/operator of the machine of the college so im just checking what are the available guide online
          Thanks again
          • adriansto
            • 2387
            The fan is located above the cylinder module. It have a filter on top of the fan.
            Power off the machine. Remove drum unit an leave the front door open. Remove front top inner cover and will see the filter. Remove the filter and check fan for obstruction. If this is ok you must change the fan.
            It is very good ideea to have service manual when you try to fix Xerox machine.
            • VINCENT23OMAN
              • May 2021
              • 14
              Thanks for the inputs. I found it and interchange the fan from the other Xerox D125 which is working fine. After interchanging the said fan the error still pop up
              Thanks again for the inputs. Maybe Il just tell my boss to call for service rep from the supplier to check further the error and identify which exact parts are needed to be replace
              • adriansto
                • 2387
                42-312 error code point to this fan not working. It rotation is monitorized by mcu. You can check the fan wires.
                First power on the machine with front top inner cover off and observe if the fan rotate. It is power with 24Vdc.
                • VINCENT23OMAN
                  • May 2021
                  • 14
                  Hello, I just follow what you instruct and notice that the fan is not working on the D125 with error code but upon removing the fan and test it in the other unit it works fine. Does the MCU the one supplying power or sending signal to the fan?
                  thanks
                  • xcopytech
                    • Aug 2006
                    • 1794
                    You will need service manual
                    • adriansto
                      • 2387
                      Figure
                      • zagrex
                        • Dec 2011
                        • 63
                        Thank you
                        see atc
                        • VINCENT23OMAN
                          • May 2021
                          • 14
                          just an update about this post:
                          Problem solved when I replaced the main iot pwd. Takes time ordering with the distributor here in oman..
                          Thank you everyone for all your inputs with regards to the error code
