C8070 No Magenta Image
  • Gaffers01
    • May 2011
    • 335
    As the title says Im working on a Altalink C8070 on the latest firmware 103.003.023.22910
    where there is no magenta on anything copied or printed including test prints.
    I replaced Drum R3, magenta developer unit, magenta developer, Image transfer belt unit, developer HVPS.
    After replacing these and doing a test print magenta was still missing and when I pulled the M developer unit back out it was completely empty, and I mean empty.
    So I presume its just dumped it straight into the waste toner bottle.
    KCY images are all excellent.
    Any guidance to what could be the issue would be very helpful
    (all toners and parts are all genuine)
  • JeeDayHS
    • Jan 2021
    • 18
    Re: C8070 No Magenta Image
    Try to switch Laser from Magenta to Cyan and check print
    • richs
      • Nov 2008
      • 261
      No lasers.LED print heads.
      • JeeDayHS
        • Jan 2021
        • 18
        I mean led print head my mistake
        • Dech1
          Senior Engineer
          • Dec 2022
          • 61
          If you had dead LHP, it will throw out an error..
          Dumping dev- you have no bias or your blank exposure lamp is not working
          Check the bias connector where the dev tank pushes into
          check your bias PWB
          switch your lamp on through service mode to see if its working..
          Run your procon on/off and check the bias readings...
