Xerox C60 Fiery EX-i 5PB (E300)
  • pdy-pt
    • Mar 2018
    • 58
    Hello together,
    I have here an integrated Fiery for a Xerox C60/C70 which shows the LED code "4f" while trying to boot. Then nothing happens. Does someone know what this means? Can't find information about this code elsewhere.
    Thank you!
  • xcopytech
    • Aug 2006
    • 1783
    Re: Xerox C60 Fiery EX-i 5PB (E300)
    Have you tried to reload software
    • pdy-pt
      • Mar 2018
      • 58
      Tried to reload software but when I switch the device on software is not loaded from USB but code "4F" appears again. Do you know what the code means?
      • xcopytech
        • Aug 2006
        • 1783
        Remove bios battery for some time. Then try to power on.
        Remove memory from slot and power on fiery.
        Fiery should beeps.
        If not then your problem is with motherboard or processor.
        For E300 fiery software must be v2.0 or v2.1
        • pdy-pt
          • Mar 2018
          • 58
          Thanks for your advice! Did that but didn't change anything. Still code "4F". Also reseated CPU.
          When i remove DIMM memory then I get code "55".
          Tried software installation with 2 different USB sticks and USB helper tool and software from Xerox site.
          • xcopytech
            • Aug 2006
            • 1783
            For e300 fiery you need v2.0 or v2.1 software.
            You need system software and user software dvd's
            • pdy-pt
              • Mar 2018
              • 58
              Yes, I did with V2.1 (should work or?) and included server as well as user files.
              • xcopytech
                • Aug 2006
                • 1783
                Yes 2.1 should work.
                If USB upgrade do not start then motherboard is next step
                • adriansto
                  • 2375
                  4f error code = in the most of situations mean defective RAM.
                  • WIWA
                    • Mar 2009
                    • 97
                    Hello together,
                    Thank you!
                    Well for sure is a hardware problem , try this take out the hard drive and check how it behaves later do the same with the interface board and see how it behave or error codes changes . Check for PS voltages as well any popped cap on the mother board specially on the CPU , memory areas ,maybe possible a faulty CPU (error 4E ) or motherboard (error 69 ).
                    Hope this help ,
                    Wiwa 72 Gonzos build v.1.0
