Xerox Color C60 - Error 077-118
  • XEROX_1111_TEC
    • Aug 2019
    • 71
    Hi
    I need help with this error code 077-118 on a Xerox Color C60
    I have replaced the transport module, inverter, right door and PWA MD IO and the Fuser.
    Nothing solved, when it jams paper stays fall out in right inverter door and always registers this error.
    What else can I verify or test?
    One pattern, happens mostly with repetitions.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox Color C60 - Error 077-118
    Do you have this fault only when print in duplex
    • XEROX_1111_TEC
      • Aug 2019
      • 71
      Yes, and this machine is face down, and never jams with single sided print.
      • XEROX_1111_TEC
        • Aug 2019
        • 71
        Jam duplex.jpg If it helps, paper stays like this when it jams
        • xcopytech
          • Aug 2006
          • 1794
          Does machine can print from tray 5
          • XEROX_1111_TEC
            • Aug 2019
            • 71
            Yes, from all trays, from A4 to SRA3
            • xcopytech
              • Aug 2006
              • 1794
              Does single side print with face down option work well?
              • XEROX_1111_TEC
                • Aug 2019
                • 71
                Yes, all print works in single sided are face down and there is not a single jam
                • xcopytech
                  • Aug 2006
                  • 1794
                  If you do not have paper in duplex module when jam is declared and paper always stay under inverter then tray module pwb and iot drive pwb can be next steps.
                  Because you have already replaced inverter and right door
                  You can try to initialize iot nvm
                  • XEROX_1111_TEC
                    • Aug 2019
                    • 71
                    I will replace tray module pwb and reset IOT NVM, and after that I will give some feedback.
                    • Dech1
                      Senior Engineer
                      • Dec 2022
                      • 61
                      (strip your duplex unit- remove reg unit, btr unit fuser unit...), remove the bushings to the feed rollers (duplex unit feed rollers x3) clean the shafts and replace or clean and swop around the bushings on the shafts. (top to bottom,bottom to top) remove the drive belt and clean all the gears and shafts that the gears run on.
                      Problem solved..
                      • XEROX_1111_TEC
                        • Aug 2019
                        • 71
                        Hi
                        After some weeks this problem maintains
                        Replaced tray module pwb, reset to IOT NVM, full NVM reconfiguration with nvm factory values sheet. Also done software upgrade.
                        Nothing solved
                        • adriansto
                          • 2388
                          Originally posted by XEROX_1111_TEC
                          Hi
                          Nothing solved
                          Write it down nvm 742-191 and 742-479 values. Set both nvms to 77.
                          • XEROX_1111_TEC
                            • Aug 2019
                            • 71
                            Hi
                            As promised here I am. Only last week I found out the solution for this error.
                            I have tried everything we have talked about and nothing solved. So I had to change my approach.
                            After some more research, I found that there is a kit of rollers and the drive belt that might have to be replaced in the transport module
                            So in the absence of those I have disassembled all peaces of the transport module, I mean all with register, 2nd bias, suction belt and even the transport plate for second face.
                            I have observed that in the pulley fittings there was a mix with toner that was acting as glue.
                            All metal was cleaned with thinner and than dried. All rollers were cleaned with a powerful degreaser.
                            2nd bias was fully aspirated.
                            After all this work i have assembled all parts
                            Besides this, I have also properly degreased all inverter rollers, inverter door included.
                            First test run was with 250 two face print with A3 80 grams paper with full success
                            Second test was the costumer printer with tested parts, also full success
                            Thanks for your help. I have written all the details because they can be useful for you and others in the future.
