Xerox WorkCentre 7530
  • damamato
    • Oct 2023
    • 8
    Lost model number (XXXXX XXXXX)and serial number (empty field).
    Can someone help me?
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox WorkCentre 7530
    Csn you enter in diagnostic mode?
    Check dc132
    • damamato
      • Oct 2023
      • 8
      In diagnostic mode dc132 there is Machine identifier code. Requires passcode.
      • adriansto
        • 2384
        How did the copier lost its data?
        Have you old machine configuration report?
        • damamato
          • Oct 2023
          • 8
          It happened after replacing the battery
          • adriansto
            • 2384
            What the error history show?
            • damamato
              • Oct 2023
              • 8
              362-310-00 IISS / Scanner -Controller communication Fail
              322-352-00 Serial number lost/missing. A Password routine may be required to write serial number
              • adriansto
                • 2384
                If you dont change any machine pwb then try to fix 362-310 error. Folow the procedure from service manual also for 322-352 error
                This 362-310 error can block the serial resincronization of the pwbs.
                • damamato
                  • Oct 2023
                  • 8
                  The customer told me that he performed an nvm initialization. Could that be the problem?
                  • adriansto
                    • 2384
                    Ussualy no problem from initialization but big problem if he did switched or changed pwbs.
                    • damamato
                      • Oct 2023
                      • 8
                      Nothing has been changed.
                      • mkdirs
                        • Oct 2014
                        • 177
                        check nvm battery then
                        reinstall firmware AltBoot with FORCED_UPGRADE file and DISABLE_DATA_BACKUP
                        Make sure the activation SIM is in place
                        Xerotk.com
                        xerox copier technician
                        • damamato
                          • Oct 2023
                          • 8
                          I lost the SIM
                          • damamato
                            • Oct 2023
                            • 8
                            I managed to get the machine to recognize the 7530 model again, but the serial number still doesn't see it. Always no serial.
                            Is the SIM unique or is one SIM of that model enough?
                            • Maurice Waffo
                              • Mar 2025
                              • 2
                              reset the device
                              please help me, altboot don't pass
