Versant 180 761-337 NVM Value meaning
  • jonjo1978
    • Nov 2023
    • 3
    Hi,
    I am new to working on Versants and I have been asked to supply xerox with NVM values from 761-337 , 761-336, 761-335, 761-334.
    What do these show and what should the values be?
    All the values were different and in the millions.
    I am assuming it is some sort of value for toner coverage/usage as the issue is to do with excessive waste toner.
  • Dech1
    Senior Engineer
    • Dec 2022
    • 62
    Re: Versant 180 761-337 NVM Value meaning
    Originally posted by jonjo1978
    Hi,
    761-334 Charge Weight of Toner Cartridge at the time of shipment K2 Toner Supply Amount of Toner Cartridge at the time of shipment (#) ASR Specification. 6500 50000 0.1g X O
    761-335 Charge Weight of Toner Cartridge at the time of shipment K1 Toner Supply Amount of Toner Cartridge at the time of shipment (#) ASR Specification. 6500 50000 0.1g X O
    761-336 Toner Accumulated Usage Amount Y Total Toner Consumption Amount since Machine Setup (#) ASR Specification (Calculation Value). 4294967295 0.1g X O
    761-337 Toner Accumulated Usage Amount M Total Toner Consumption Amount since Machine Setup (#) ASR Specification (Calculation Value). 4294967295 0.1g X O
    761-338 Toner Accumulated Usage Amount C Total Toner Consumption Amount since Machine Setup (#) ASR Specification (Calculation Value). 4294967295 0.1g X O
    761-339 Toner Accumulated Usage Amount K2 Total Toner Consumption Amount since Machine Setup (#) ASR Specification (Calculation Value). 4294967295 0.1g X O
    761-340 Toner Accumulated Usage Amount K1 Total Toner Consumption Amount since Machine Setup (#) ASR Specification (Calculation Value). 4294967295 0.1g X O
    761-341 Maximum Number of Printable Copies Y Number of Printable Copies of Toner Cartridge (#) (MIB supported). *Calculate from Assumptions (such as Paper Size, AC) V2100/3100/3100iP_55 kPV, V80/180/180iP_22 kPV 22000 4294967295 1 PV X O
    761-342 Maximum Number of Printable Copies M Number of Printable Copies of Toner Cartridge (#) (MIB supported). *Calculate from Assumptions (such as Paper Size, AC) V2100/3100/3100iP_51 kPV, V80/180/180iP_21 kPV 21000 4294967295 1 PV X O
    761-343 Maximum Number of Printable Copies C Number of Printable Copies of Toner Cartridge (#) (MIB supported). *Calculate from Assumptions (such as Paper Size, AC) V2100/3100/3100iP_55 kPV, V80/180/180iP_22 kPV 22000 4294967295 1 PV X O
    761-344 Maximum Number of Print Possible K2 Number of Printable Copies of Toner Cartridge (#) (MIB supported). *Calculate from Assumptions (such as Paper Size, AC) V2100/3100/3100iP_50 kPV, V80/180/180iP_20 kPV 20000 4294967295 1 PV X O
    761-345 Maximum Number of Print Possible K1 Number of Printable Copies of Toner Cartridge (#) (MIB supported).
    *Calculate from Assumptions (such as Paper Size, AC) V80/180/180iP_20 kPV
    • jonjo1978
      • Nov 2023
      • 3
      Thank you - does that relate to expected page coverage for toner yield or actual toner used?
