Xerox D95 Image Defekt
  • Quasar1975
    • Mar 2023
    • 9
    Hello, dear community members!
    I am experiencing an issue with my Xerox D95, it is an image defect. The image stretches and doubles. Please refer to the attached files containing an original PDF and the corresponding printed page. I have two D95 machines, and I've tried swapping almost every component, including the Registration Unit, Transfer Belt Unit, Drum Unit, and Fuser Unit, "Xero. Deve. Transfer Belt Drive" but nothing has resolved the problem.
    Your assistance would be greatly appreciated.
    Thank you!
  • adriansto
    • 2384
    Re: Xerox D95 Image Defekt
    Thank you!
    Where is the lead edge on the image?
    Do you see same 'defect' on transfer belt?
    • xcopytech
      • Aug 2006
      • 1793
      A3 or A4 paper?
      I think that D95 do not have transfer belt on which you can see defect.
      Image is transferred from drum to paper directly.
      Print test print 6 from diagnostic on A3 paper and post pic here
      • Quasar1975
        • Mar 2023
        • 9
        Thank you very much for your so quick answer!
        The up edge is lead, the problem is in the tale part of the sheet.
        I don't know how to make a stop copy to see the image on the transfer belt. Please advise.
        • xcopytech
          • Aug 2006
          • 1793
          You can not see image on belt.
          D95 do not have IBT. Image is tranferred from drum to paper.
          Print test pattern 6 from diagnostic on A3 paper
          • Quasar1975
            • Mar 2023
            • 9
            Here it is. I have made a firmware update and completeNVM Initialization and the problem turned upside down, now it starts on the lead edge.
            • xcopytech
              • Aug 2006
              • 1793
              You fuser motor work faster then drum motor.
              You have to check nvm for fine adjust for drum motor and for fuser.
              • Quasar1975
                • Mar 2023
                • 9
                Thank you very much!
                Should I play with NVM 741-001 and 744-162?
                • xcopytech
                  • Aug 2006
                  • 1793
                  Yes, try first with drum fine adjustment
                  • Quasar1975
                    • Mar 2023
                    • 9
                    You are an magician! Thank you so much! I have spent a week, trying to fix it, and now it works! Drum speed was already increased by previous owner, decreasing lead to jams, so I have increased a fuser speed and now the printer works just fine!
                    Thanks again and I wish you all the best from Prague!
                    • xcopytech
                      • Aug 2006
                      • 1793
                      Nice to have feedback.
