Versant 80 Maintance
  • Samxerox
    • Apr 2023
    • 44
    Just after buying 2 versant 80s and wondering if there is any regular maintance I should be doing.
    Especially since I do not have tech support and there is no one local I can call in.
    I have been running a xerox 700 this way for 5 years so not afraid to get my hands dirty.
  • xcopytech
    • Aug 2006
    • 1792
    Re: Versant 80 Maintance
    Nothing special, just try to find service manual
    • JR2ALTA
      • Feb 2010
      • 2030
      Keep drums, rollers and BTRs on hand. Everything else runs pretty smoothly.
      • Samxerox
        • Apr 2023
        • 44
        Hi can you expand on this.
        Drums I understand as for Btr im gussing you mean 2nd btr unit.
        But what rollers are you refering to.
        • adriansto
          • 2383
          If you use mostly coated paper you will change often the 2nd BTR. With drums was problems but now they are ok but also the drum life depends if you use OE toners. Paper feed rollers registration rollers.
