Xerox 7665 firmware search: 040.033.50500
  • ondemandprint
    • Sep 2016
    • 87
    Hello.
    I'm searching for early AltBoot firmware. My 7665 stuck on Scanner Engine update after electric disaster at our district.
    I recovered it some times for last years but it stucks at 0% this time.
  • adriansto
    • 2392
    Re: Xerox 7665 firmware search: 040.033.50500
    Originally posted by ondemandprint
    Hello.
    This software version is upgrade for Patriot to Lexington machine.
    You must have pws tool ( altboot software from WCPP tool )
    • xcopytech
      • Aug 2006
      • 1794
      If you want to use xerox pws and dc102 to reload machine software you can use any full software version as 040.033.53050. After that you can upgrade machine to newer version
      • ondemandprint
        • Sep 2016
        • 87
        You're right!
        Can I use such firmware? WC7655/7665/7675 SPAR software version 040.033.53375 and instructions - WorkCentre 7655/7665/7675 - Xerox
        Or there is a special AltBoot FULL firmware as on Xerox 56хх for example? Can you send me full firmware in this case?
        • xcopytech
          • Aug 2006
          • 1794
          This software version from xerox is just update dlm file.
          You need full software version and also need xerox pws software and wcpp diagnostic tool to be able to load software to machine
          • ondemandprint
            • Sep 2016
            • 87
            I've both and service documentation. What is "full software version"? And can you help to obtain it?
            • xcopytech
              • Aug 2006
              • 1794
              Full software use dc102 from wcpp diagnostic navigator to upgrade machine software.
              Simple dlm file can be upload to machine over network or by altboot
              • ondemandprint
                • Sep 2016
                • 87
                Can you help with this "full software"?
                • adriansto
                  • 2392
                  What version of pws do you have?
                  What version of WCPP?
                  • ondemandprint
                    • Sep 2016
                    • 87
                    PWS 11.3
                    WCPP 040.033.50363
                    • xcopytech
                      • Aug 2006
                      • 1794
                      You will need wcpp 040.033.50369
                      • ondemandprint
                        • Sep 2016
                        • 87
                        Can you help me with both?
                        • adriansto
                          • 2392
                          PWS 11.3
                          WCPP 040.033.50363
                          This mean pws run on Win7 32 bit. You must have software patch for any version of WCPP that run on Win7.
                          This patch allow dc102 to works. WCPP 50363 or 50369 need the patch. This is software and this is the patch.
                          • xcopytech
                            • Aug 2006
                            • 1794
                            Dc102 patch is part of 50369 diag
                            • ondemandprint
                              • Sep 2016
                              • 87
                              Can you send me all this files?
