Xerox 6204 Wideformat Unable to Copy/Scan/Print after resetting settings
  • manuelubau
    • Aug 2011
    • 62
    Hello Everyone!!
    I am trying to figure out how to come out of this hole with my Xerox 6204. While trying to troubleshoot an issue with the copier, I ended up resetting the settings for it using the service mode (I know I should have backed up everything but I didn't ). The issue that's happening now is that when we attempt to make a copy or scan, the "feeder" doesn't pull the paper and becomes ready for copy/scan. Before I restored the settings it used to be able to operate normally just had a copy quality issue. I am still able to print using the website for the copier and the quality prints from service mode. I am assuming some values may have been erased or not restored properly. anyone has an idea on how to find all the values and what they should be? or what this issue could be?
    Thanks for the help!
  • adriansto
    • 2369
    Re: Xerox 6204 Wideformat Unable to Copy/Scan/Print after resetting settings
    It is with BPS print server or AccXes controller?
    What was the procedure for resetting the machine?
    • manuelubau
      • Aug 2011
      • 62
      Hello! it is with BPS Print server. I basically logged into service mode, and loaded settings from Hard Drive for all options available. and downloaded program from Panel as well.
      • adriansto
        • 2369
        Sorry I did not understood. DC361 is the only one routine you can load settings from diagnostic mode.
        But you say you did not save anything before reset. What was the routine number you used to reset machine?
        What program was downloaded from Panel?
        • manuelubau
          • Aug 2011
          • 62
          Hello Sorry if I am not too clear. I am not very familiar with this copier but there are no technicians available in my country that can service this copier model.
          What I did specifically is the following:
          1. Log into service mode
          Here I have multiple options: UI, IIT, CP-CONT, IOT, SYSTEM, PANEL DATA DOWNLOAD, END.
          I went into each of these options and used the "System Data Save/Restore" option and used the "Restore (HDD)" option
          When I went to PANEL DATA DOWNLOAD it has the following options:
          PROGRAM, TEXT, FONT, ICON.
          I used the program download.
          • manuelubau
            • Aug 2011
            • 62
            sorry yes it was DC 361 I used to load settings from HDD
            • adriansto
              • 2369
              Select MACHINE STATUS button from control panel then SOFTWARE VERSION from MACHINE INFO tab.
              Make photo of the screen. Then go to diagnostic mode , choose dc108 make photo of display.
              Same for dc120 and dc122. Post photos here or send them to stoadis@gmail.com.
              Machine was new when you buying it?
              It is strange to restore data when you dont save anything.
              • manuelubau
                • Aug 2011
                • 62
                The copies was bought new a very long time ago. We've owned this copier for more than 10 years. We've done most of the maintenance ourselves. I believe the issue lies in the values of the registers for the machine. they probably got restored to the wrong values. I am attaching here the pictures you asked. Do you know if there is any book that contains the values of each register? I know a lot of copiers come with a small card on the doors with all the values for when you do a restore or memory clear.
                • adriansto
                  • 2369
                  Sorry but the photos are too small. I do not see anything. Dc 120 photo is show error code. What is that code?
                  If machine was new inside the door pocket is or was a list with nvm ( non volatile memory ) values.
                  Perhaps this is you name registers.
                  • manuelubau
                    • Aug 2011
                    • 62
                    I was able to fix the issue by using the function DC131 and selected ITT/IPS All System Data Initialize. this allowed me to print, copy and scan again! The error code you saw was a paper jam at the original feeder (it was caused by us trying to feed the original when it wasn't pulling the paper. I am back to facing the image quality issue and trying to solve that. I'll try to find those values hopefully they weren't lost. is it a document/list? I see a black sticker in there as well but it doesn't look like any NVM values.
                    Print-Quality hosted at ImgBB — ImgBB
                    • adriansto
                      • 2369
                      If the machine was new then the list of nvm was there.
                      You can save the actual values of nvm using dc361 from diagnostic mode.
                      You can save it on internal hdd or usb stick. Because machine is so old use old usb stick 256MB-1GB.
                      • xcopytech
                        • Aug 2006
                        • 1783
                        What have you done to fix print quality problem?
                        Clean or replace BCR
                        Check developer, mag roll and btr.
                        If you have cq problem evry 251mm then you have problem with drum.
                        Print quality can not be fixed by NVM values.
                        • manuelubau
                          • Aug 2011
                          • 62
                          We have a problem with very low density (Almost blank) columns every 80 mm. According to troubleshooting manual, it may be related to Mag roll, however we've already tried replacing pretty much everything we can think off (Drum, mag roll, developer unit) According to the manual it may be related to Xerographic calibration.
                          • manuelubau
                            • Aug 2011
                            • 62
                            also yes, we have replaced BTR and BCR. no luck so far....
                            • xcopytech
                              • Aug 2006
                              • 1783
                              You can not resolve banding problem with calibration.
                              You have uneven toner transfer from developer assy to drum.
                              If I can see well on pic you also have darker band on print.
                              If that distance is about 251mm then you also have problem with drum.
                              If you replaced mag roll then check bias connection on developer assy
