Looking for a feature enablement code for a Xerox Workcenter 7125 to enable Scan to USB drive. I have tried 3 different codes labeled for 7120 but all have resulted in "Your request was not processed" after hitting Apply.
I am entering these codes under Properties > Feature Enablement in the web portal for the printer. Thank you for your help in advance.
If you have an alternative way to scan to a Windows 10 laptop from one of these machines, that would also be good to know (it cannot be connected to the network at this point in time, hence the need for Scan to USB drive). I am currently able print over a USB A to USB B cord.
