Workcentre 7655 configuration mismatch
  • Skitchin1
    • Apr 2024
    • 2
    Hi i have a workcentre7655. We Moved offices it got dropped now when i turn it on we get a message Not ready- configuration mismatch exits. Automatic conf has detected the hardware mismatch.
    Image disk- present
    Embedded fax- 1 line
    Network controller- present.
    If i click yes i get a configuration error. One or more accessory connection may have incorrectly. Then tell me to turn off.
  • Skitchin1
    • Apr 2024
    • 2
    Re: Workcentre 7655 configuration mismatch
    Click yes and no auto selects.
    • adriansto
      • 2392
      First step is to reseat all connectors and electronic boards from CCM and network controller.
      Also check the fireware cable that links CCM and net controller.
      It is good ideea to have disgnostic tool and read the machine error codes.
      • hnami
        service technician
        • Nov 2023
        • 171
        Image disk- present
        I have had this problem before
        I think I replaced the backup battery
        • mkdirs
          • Oct 2014
          • 177
          yes these old machine have fireware cable problems all the time
          you need to check the fieware cable also the nvm 3v yellow battery
          and you need to use the sim card to install some services
          Xerotk.com
          xerox copier technician
