C70 Flash Code (5 flashes)-LVPS or HDD issue?
  • JustCCN
    • Nov 2022
    • 6
    My C-70 powers on and only flashes all of the lights five time, then stops and continues the flash code. Research indicated it might be a LVPS. I've checked all voltages and everything tests good. Is it possible this is the HDD? I tried to reload the software using the back side USB and placing the file in a folder named "Alt Boot",as a Xerox tech told me to do, but it does nothing.
    If I am loading the software wrong, can someone please advise me on the correct steps?
    If I have the wrong software, is there somewhere I can download the correct versions?
    Thank you in advance for your help.
  • Jack79
    • Jul 2014
    • 312
    Re: C70 Flash Code (5 flashes)-LVPS or HDD issue?
    I have no experience with c70 however AltBoot should be written together without gap between Alt and Boot
    • xcopytech
      • Aug 2006
      • 1794
      24v from lvps to UI.
      Replace lvps.
      You can not altboot xerox c70.
      To reload software on c70 create folder dwld on usb and put dlm file in it.
      You will not be able to reload software until replace lvps
      • JustCCN
        • Nov 2022
        • 6
        Thank you for the help. I really appreciate it.
