Magenta and cyan not showing
  • Reeves
    • Apr 2012
    • 294
    [Misc] Magenta and cyan not showing
    Hi Techs
    I have a Xerox altalink C8155 when I print or copy magenta and cyan colors are not coming out when I print the pattern test magenta and cyan are coming out blank but black and yellow are Okey what could be the problem please assist me
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Re: Magenta and cyan not showing
    Originally posted by Reeves
    Hi Techs
    LED Printheads
    HVPS
    IBT
    Developers
    Dispense Mechanism
    or something else entirely.
    You are going to have to do some more troubleshooting.
    • Reeves
      • Apr 2012
      • 294
      Originally posted by Murv
      LED Printheads
      HVPS
      IBT
      Developers
      Dispense Mechanism
      Ibt is Okey
      Developer powder I just added new ones magenta and cyan
      • Reeves
        • Apr 2012
        • 294
        LED Printheads
        HVPS
        IBT
        Developers
        Dispense Mechanism
        For trouble shooting purpose I swapped Black and cyan developer units black was blank cyan was visible
        • xcopytech
          • Aug 2006
          • 1794
          First check LPH for magenta and cyan,
          • Reeves
            • Apr 2012
            • 294
            I swapped yellow and cyan cyan on yellow is working Okey yellow on cyan blank
            • Murv
              • Mar 2021
              • 182
              So if you add up all the swapping and testing, what does that leave?
              • Reeves
                • Apr 2012
                • 294
                Magenta and cyan not charging
                • Murv
                  • Mar 2021
                  • 182
                  Yep. Sounds like where I would look next.
                  • xcopytech
                    • Aug 2006
                    • 1794
                    If you do not have charge on drum you should get full tone background print.
                    • adriansto
                      • 2384
                      Hi Techs
                      In the old days, the technician learning the xerographic process, did not start with the replacement of parts
                      • Reeves
                        • Apr 2012
                        • 294
                        What could cause that? Can firmware be the issue
                        • Jack79
                          • Jul 2014
                          • 312
                          If you installed black dev unit into cyan and cyan was visible then do not you think the problem is with the cyan developer assy? You said that cyan and yellow developer powder was replaced. Maybe pipe blocked or mag roller not rotating - broken gear?
                          • Reeves
                            • Apr 2012
                            • 294
                            Black and yellow are Okey so I swapped black and cyan without removing developer powder cyan developer units worked on black and black developer unit on cyan it's blank developer units are rotating all are Okey
                            • Jack79
                              • Jul 2014
                              • 312
                              What about shopping cyan drum with yellow?
                              Is transfer belt fine?
