Xerox Docucolor 250 diagnostic tool software,
  • Onetouch
    • May 2008
    • 62
    I need Xerox Docucolor 250 diagnostic tool software,
    I got the service manual but I need the diagnostic tool software in order to be able to go PWS mode to clear the error.
    By the way how can I set NVM 744-156 to 0 in order to clear 010-324
  • pal.xerox
    Docucolor 250 010-324 reset
    hi please see below and folow
    To enter the CE mode:
    1. <LI id=svc.olym.0000088025>Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
      The CE Access Number screen will appear.
      <LI id=svc.olym.0000088032>Enter 6789 and press Confirm.
    2. The topmost area of the UI display will be reversed to let the user know that the mode has changed to the CE mode .
    3. then selcet NVM Read Write and enter appropriate chain and function code.
    • TechMate
      • Mar 2008
      • 285
      Above instruction is correct. However you need to reset 744-352 to 0 for error code 010-324. If the same fault occurs, do NVM initialization on IOT only
      • china
        Does anyone have the Xerox diagnostic tool software? Thanks!
        • pal.xerox
          250 diagnostic tools
          yes i have you can buy to me.
          contact to me at pal.xerox@gmail.com
          • ratacusca
            I have the pws tool write to dante125_1@yahoo.com.mx
            • ratacusca
              I have the pws tool write dante125_1@yahoo.com.mx
              • XeroxTechBrazil
                • Aug 2008
                • 199
                Check Your Messages
                OneTouch, check your personal messages.
