Xerox 7242 Fault Codes 089-311
  • thecorfu
    • Jul 2025
    Hi there,
    My Xerox WorkCentre 7242 told me this Error Message (089-311) after i cleaned the ibt belt cleaner.
    Has anybody known issues ??
    thanks
  • pal.xerox
    hi,
    you need to celan ibt belt home postion sensor. reamove the ibt assy and then u can see thsi sensor. also check the patch of ibt belt is it in ok contidion at ibt belt . patch u will find upper site of the belt.
    regards,
    pal[
    QUOTE=thecorfu;77185]Hi there,
    thanks[/QUOTE]
    • thecorfu
      is there any easy way to remove ibt assy. ?
      i think i have to call xerox service center
      thanks.
      • pal.xerox
        ithinkits not very difficult to remove ibt assy.
        u jusy need to open front inner cover then u can easly access .
        thanks.
        • Roberto_Blanco
          • Mar 2010
          • 12
          Re: 7242 089-311
          Thanks alot. Your message was the solution to my problem ! Cheers.
          Originally posted by pal.xerox
          hi,
          regards,
          pal
          • Lestat
            • Mar 2011
            • 3
            Re: Xerox 7242 Fault Codes 089-311
            Sorry wrong post. :s
