DC250 paper jam
  • rgbprint
    • Nov 2008
    • 15
    DC250 paper jam
    From tray5 13x19 paper jam in fuser.
    erroe code 077-106
    Thanks in advance
  • copytech200X
    • 264
    erroe code 077-106
    Thanks in advance
    chk paper size setting in pc printer driver and measure the paper size ...
    • rgbprint
      • Nov 2008
      • 15
      paper setings is ok, but still the paper jam. Dc250 only done 10k copies?????
      • TechMate
        • Mar 2008
        • 285
        Clean the anti-static brush or remove if not cleanable. Try to set the screw setting gap of the stripper blade down by 2mm. There is no adjustment of this baffle in edoc, item 8.2.7 but this may help
        • rgbprint
          • Nov 2008
          • 15
          Thanks!! Now work fine.
          • copytech200X
            • 264
            is it same adjustment applied to tarzan ?now i adj it 15mm as default ...what's your adjustment ?
            • TechMate
              • Mar 2008
              • 285
              factory standard is 18-19mm. We use 17-18mm
              • metal-micky481
                DC250 Jamming
                Did you solve the paper jamming on you DC250. If so how was the fault fixed.
                • TechMate
                  • Mar 2008
                  • 285
                  The problem was solved.
                  • sanimir
                    • 183
                    Re: DC250 paper jam
                    please explain, i have same problem, also photo be fine
