Docucolor 12, Fiery Problem
  • aroquesp
    • Jun 2025
    Hi, I have a Docucolor 12, seems that the Hard Disk of the Fiery is damaged, when I turn it on, the hard disk only makes a click, click, click, sound and nothing happens, what can I do?
    Best Regards,
  • davidj7
    • 1107
    you can put a new IDE hard disk 40 gb or so and i presume you don't have the system software.if you are having X12 ver 1.5 then i could give you the installation CD's otherwise post your fiery model and hopefully some one could get you the software
    a machine is only as good as your tech : source:screwtape ; the scary one
    • TechMate
      • Mar 2008
      • 285
      Best Regards,
      Another alternative if you don't have the system s/w is to have the HDD be diagnosed and fixed by a recovery software which can be d/loaded from the i/net for free (just google search it). Better yet get an HDD recovery professional to do the job
      • aroquesp
        • davidj7
          • 1107
          i could send you the system software of cobra, do u have a cd drive on your cobra?
          • aroquesp
            Thanks!!!!!!!!!
            Yes I have a cd drive on my cobra.
            Thanks a lot...
            • pal.xerox
              fiery x12 v1.1 system software
              hi ,
              can you please help me how we can make a diffrence between fieryx12 and cobra ?
              i want to install fiery v1.1 system software but i don't know about the proccedure how to install and how many cds are required for this task ?
              i have only one cd of system software in mdf format, i try to boot with this but didn't get any response.
              • aroquesp
                Thanks!!!!!!!!!
                Thanks a lot...
                Are you going to help me?? I really need the Cobra System Software.
                Best Regards,
                Antonio
                • jparks39
                  • Jun 2009
                  • 19
                  If u can get a ghost image ver1.5(meaning,someone has built a fiery 12 system with all the drivers,configurations already done) for u. It takes disk 1/2 to get it up and going. Of course that your fiery 12 has all the standard factory parts. The hdd can be bought(new) and the size doesnt matter. It will format the patition with the ghost image. I have done this in the past and not knowing what the heck I was doing and it work. Good luck!
                  • davidj7
                    • 1107
                    antonio check p.m
                    • ultratex
                      Re: Docucolor 12, Fiery Problem
                      I put a new IDE hard disk 40 gb I dont have the system software.if you have Fiery X12 ver 1.5 then i could give me, the installation CD's ..
                      • Enzo
                        • Jul 2009
                        • 407
                        you have version 1.5? in what language do you need?
                        • ultratex
                          I'm from Brazil. but we use Inglish, portuguese or spanish, Thanks
                          • Enzo
                            • Jul 2009
                            • 407
                            wait my news...
