Xerox DC12 message printer off
+ More Options
Posts
  • dolcevino
    • Mar 2008
    • 26
    Dc 12 restarts by himself and no error cod on fiery
    message printer off
    I can copy bath cannot print
  • johnner66
    • Mar 2009
    • 265
    first check the interface cable wherether you connect correctly there is print n scn make sure you connected correctly then check the m/c setting 752-008 is 2 n 759-053 is 1 n 759-054 is 1 good luck
    • dolcevino
      • Mar 2008
      • 26
      Thank you! johnner66
      It was 759-053 and 759-054
      We asked local xerox people what is wrong they did not want to say.
      You help is therefore bigger.
      • bmt_hr
        • Mar 2011
        • 128
        Thanks johnner66........ thats solution works.....
        • johnner66
          • Mar 2009
          • 265
          Re: Xerox DC12 message printer off
          you are welcome may i know where you from and what copier you working as
          • bmt_hr
            • Mar 2011
            • 128
            I am from Croatia. Just yesterday I solved problem again on one machine DC12. Thanks
