Doc 12 Yellow color not printing
  • davidj7
    replied
    do you hear any odd sound of gears slipping when the yellow dev assy comes into position o the rotatory.I bet on techmates post.Wierd place to look on IBt clutches but worked for me.
  • Milo Wilson
    replied
    If it is just yellow and everything else is fine, then check the yellow dev. assy to see if you have stripped gear teeth or seized bearing.
  • TechMate
    replied
    You need to test your deve clutch, IBT clutch and 2nd BTR clutch; replace if faulty. Most likely it'll be a deve clutch failure
  • Jaroz
    Guest started a topic Doc 12 Yellow color not printing
    Some one can help me for Doc 12 issue. Only yellow color is not printing all other colors are fine. System is not showing me any errors.
    Does changing development housing will resolve this problem? or I need to change developer....
    My contact email address is tech7860@gmail.com
    Please advice.
    Thank you.
    JG
