error compatibility toner dc230
  • Enzo
    • Jul 2009
    • 407
    hi friends, I am new in the forum. excuse me for my bad English. I will do the possible one to make to understand me and I hope that you succeed in helping me. I have a problem with a toner xerox 230. practically this message of error appears: "non compatible copy/print cartridge". how can I resolve this problem? all the toners that I have acquired show the same error. they are toner USA therefore they won't be compatible with my machines (Europe, Italy). I believe is this the problem. I thought that it could be resolved. I wished to know if in the settings of the machine it is possible to eliminate this message of error. Thanks
  • jeanpaul
    • Mar 2009
    • 117
    you should change the Chip in the toner module
    • Enzo
      • Jul 2009
      • 407
      I know it but have told me that it is possible to obviate to the problem changing some parameter in the settings of the machine.
      • Enzo
        • Jul 2009
        • 407
        is it possible?
        • Bhante
          • May 2009
          • 45
          Just had a look in the service manual. Should be possible with the dC131 NVM Read/Write routines, chain 29/10: country code. Take a note of what it is currently set to before changing it, so that it can be set back later. The default is 1, which I imagine is the US.
          • XFather
            • Jul 2009
            • 22
            drum
            What cod error you have?
            Is possible to have many problem:
            NVM corupt
            bad software on UI
            hardware problem
            etc.
            Sorry for my english, too.
            Regards
            • Enzo
              • Jul 2009
              • 407
              have tried to change that code but the same doesn't work!
              • xcopytech
                • Aug 2006
                • 1792
                You have two options
                1 to replace chip with european or
                2 to reload USA UI firmware to machine (to do this must have xerox pws)
                • Enzo
                  • Jul 2009
                  • 407
                  I haven't xerox pws!
                  • xcopytech
                    • Aug 2006
                    • 1792
                    you can buy european chips for xerox dc 320 machine
                    • Enzo
                      • Jul 2009
                      • 407
                      I believe both the only alternative. thanks
                      • Enzo
                        • Jul 2009
                        • 407
                        I will try to change that value. I hope that I succeed in resolving the problem.
                        • Bhante
                          • May 2009
                          • 45
                          I thought you said you had already tried it? Are you getting into service mode?
                          • Enzo
                            • Jul 2009
                            • 407
                            Tomorrow I will try to change that value. In these days I have not had the possibility to use the machine. I hope that I succeed in resolving the problem!
                            • Enzo
                              • Jul 2009
                              • 407
                              Hi friend. this morning have tried to change that value putting at random some numbers but yet doesn't work! the number of the "country code" was planned on 1. which number do I have to put for making to work my machine? thanks
