Phaser 850DP fault code
+ More Options
Posts
  • vitkh
    • Jun 2025
    Hi! Could anyone please advise me what does the fault code 22.024.01 mean for Tektronix Phaser 850DP? Thanks for any info. I can't seem to find anything about this.
    Vitali
  • serviceman
    • Jun 2009
    • 71
    From the 850 service manual:
    22,024.01 The indicates that the printhead was not parked when powered off
    In the 840/850 this error code may be reported in conjuction with other faults that cause the
    printer to reset. This code is not related to media jams.
    Usually means machine was unpluged or a power surge occured...causing the machine to power down while not in home position. You might get away with just repowering the machine up...or you will have to manually rehome the printhead and then turn it back on.
    • vitkh
      Ops... Just found out that I have a bunch of those fault codes...
      15.003.44
      15.004.45
      08.001.44
      Would appreciate any info on these... Thanks a lot.
      • serviceman
        • Jun 2009
        • 71
        Are these all on the same machine!?
        • vitkh
          Thanks... The original problem is that there is excess of toner on the printed pages, and, more importantly, there is a vertical line (more towards the right side of the page), probably about 1/2 inch wide, where there is nothing printed. When I open the top cover, and lift the blue plastic piece, I can see that on the big clear roller there is a band of black ink (going around this roller) exactly where this line occurs. Is this a known problem or not? I would appreciate any ideas on how to fix this...
          • vitkh
            Yes, the same printer.
