How can i remove a docucolor 260 belt ? 042-326 error
  • hector787
    • Aug 2025
    How can i remove a docucolor 260 belt ? the problem is the 042-326 error, i did the NVM RESET CODE 741-105 AND nothing... i am trying to check the reflector but i dont know how to remove the belt.
    wow i know how to remove an Igen 3 Belt .. but not an docu260 belt .... ironic..
  • Moxicopy.com
    NEED HELP
    How did you fix this problem, Xerox can't service my machine anymore? I have tried all of the NVM things and none work. HELP!
    • XFather
      • Jul 2009
      • 22
      Try to remove 2 screw and move drawer in the service pozition.
      • Moxicopy.com
        I got the belt out and adjusted the sensor and nothing is working. I have reset the NVM and initialized the NVM. My problem now is where is the reflective tape at?
        • XFather
          • Jul 2009
          • 22
          Inboard.
          Please verify sensor and edge sersor, be sure it is OK
          • Moxicopy.com
            WORKS THANKS!
            • msjjharrell
              Reflective tape is inside outer edge of belt. There is one on each side across from each other, they are shiny. Sometimes they will peel up at the edges or may just be dirty. You can flip the belt around if one side has been damaged.
              • kalindd
                • Jun 2008
                • 192
                Mate! Take a look at the date of the post!
                It's more than an year ago.
                But it's good that you are trying to help.
                • msjjharrell
                  Thanks, my bad, thought I was in current posting.
                  • azprint
                    Re: How can i remove a docucolor 260 belt ? 042-326 error
                    I'm having the same problem, but I don't know where the reflective tape is. Do I have to remove the belt from the machine? If so, how? Thanks for your help.
                    • XFather
                      • Jul 2009
                      • 22
                      Inboard on the inside of belt. You need to remove belt from machine.
