Hello!
I'm new to the forum. I'm self-maintaining a Xerox 2045 that I just purchased with a Fiery EX2000d controller and a high capacity feeder (DC131) / Tray 4 option.
Problem is, I cannot figure out how to print to Tray 4 through the Fiery using the driver in Windows (2000 or Vistal using the XP driver).
The Printer itself knows Tray 4 is there and will use it if you print from the scanner glass. However it shows up as being "inhibited" for auto-selection (red color on the touch panel.) But it works fine, powers up and initializes, and will print if you're doing a scan job.
Also, if you OPEN Tray 4, the Fiery displays a red flashing message on the flat panel clearly stating that "Tray 4 is open."
HOWEVER, it is not available in the driver as a tray selection on print jobs from workstations, and when you have the "Two Way Communication" setting turned on in the Driver Properties and you click the "Update Driver" button, it does NOT show Tray 4 and in fact will remove it from the Installed Options list if you have manually placed it there.
I believe the NVM location is set properly (DC131 NVM Read/Write through Diagnostic mode) but no matter what I try, I cannot use Tray 4 from any programs using the Fiery driver on my workstations talking to the Fiery RIP.
The RIP is an EX2000d 2.0 SP2 and is running Command Work Station 4.1.0.30.
All help greatly appreciated.
