xerox 8830
  • copytech200X
    • 264
    #16
    problem lies at the N5T controller ..
    • davidj7
      • 1107
      #17
      yes i know problem lies with N5T, any suggestions on where to look for a fix?
      a machine is only as good as your tech : source:screwtape ; the scary one
      • XeroxTechBrazil
        • Aug 2008
        • 198
        #18
        You have the service manual, right?
        You have the controller service manual, right?
        • davidj7
          • 1107
          #19
          yes techbrazil i have manual but not making any headway :-(
          • xcopytech
            • Aug 2006
            • 1794
            #20
            when power on controller and 8830 watch on 10 red leds (on controller main board), and see which leds stay on.
            • davidj7
              • 1107
              #21
              all led remain on
              • xcopytech
                • Aug 2006
                • 1794
                #22
                Check for loose or disconnected components on the Main PWB.
                Check all dc voltages from Power Supply PS1 to the MCU
                If OK, replace Main Controller PWB
                • copytech200X
                  • 264
                  #23
                  check power supply 25vdc PL 1.1B item 9.
                  • AjitN
                    • Mar 2009
                    • 287
                    #24
                    If all the leds are on, right from powered on, it means controller is not passing the self test. I hope you have already checked the RAMs.
                    • davidj7
                      • 1107
                      #25
                      this machine is located in bombay.
                      • JustManuals
                        • Jan 2006
                        • 9838
                        #26
                        Is that good?
                        • davidj7
                          • 1107
                          #27
                          250 miles from AjitN's location
                          • JustManuals
                            • Jan 2006
                            • 9838
                            #28
                            oh !
                            • AjitN
                              • Mar 2009
                              • 287
                              #29
                              Who R u.
                              I know most od the engrs in Mumbai who manages 8830.
                              Ypu r some body not from the lot.
                              Please replay.
                              • AjitN
                                • Mar 2009
                                • 287
                                #30
                                sorry my typo mistake.
                                who r u?????
                                u r not 8830 engr.
                                please get in touch with engr or proper knowledge persone like shaileshbhai
