Xerox 5328
  • Dr. Mansour
    • Jul 2025
    Xerox 5328
    I have cured the heater problem but don't know how to reset the u4 code.........any ideas?
  • Wild Bill
    • Jul 2005
    • 774
    U4-1 (Fusing Fault)
    Solution: Power OFF, Wait 10 Seconds, Then Power ON
    NOTE: Power OFF/ power ON is a system reset which will re-adjust the copy quality and reset fault codes.
    If your machine displays a different fault code after a power OFF / power ON, restart your search with the new Fault Code.
    Power OFF the machine using the main power switch on the rear, left side of the machine.
    Wait 10 seconds and then power ON the machine.
    Izzy
    • Falcon1
      Hi,
      Power OFF, Wait 10 Seconds, press button zero then Power ON
      enter code 20-3, press the start button. the message, dn, displayed.
      switch off the copier, then on
      it's Ok
      • miguel c
        to clear the U4 in the xerox 5328: switch on pressing simulneouly 0 button;than 20-start and 3-star; message done will display. off-on.
        miguel c
