docucolor 12 - need help color is off
  • ygeezzy
    • Aug 2009
    • 33
    need help for some strange reason the color on the printer is off.... when i print blue it comes out purple not sure what to do please help
    thanks Jimmy S.
  • GusG
    • Jul 2008
    • 198
    Calibrate. There's only a fine line between blue and purple so if your blue is borderline and your printer is adding a bit of magenta or reducing a bit on the cyan it's bound to become purple. I've had this happen on my DC2060 and it was easily cured by calibrating it.
    • Lotar
      • 76
      calibrate.
      • ygeezzy
        • Aug 2009
        • 33
        i try to calibrate it but still coming out purple not sure if im doing it right... there is a claibration options: setup calibration, calibrate, and remove claibration... when i go to calibrate it says calibration set: normal, heavyweight & extra heavyweight...i select heavyweight because thats what we use to print on are paper then it ask to print measurement page... it prints out a autocal measurement page with colors... then it ask to measure page... i put the autocal measurement page on the copyer it scans then it prints comparison page....but when i print it still comes out purple...am i doing this right???
        • ygeezzy
          • Aug 2009
          • 33
          • xcopytech
            • Aug 2006
            • 1794
            CALL A TECH
            • davidj7
              • 1107
              he he he. who needs a tech when there is copytech :-)
              a machine is only as good as your tech : source:screwtape ; the scary one
