Xerox 116-330
  • domus electro
    • Jun 2025
    Xerox 116-330
    I have a disk replaced in to the workcenter M24. But i get a new error 166-330. The error is still not on the forum, is there anyone who can help me?
    Thx
  • TzALbg
    • Dec 2007
    • 111
    Power down machine and unplug the HDD (PL13.1 item #14). Now perform GP3, steps 1 and 2 only. Machine should fault out with a 116-330 (HDD fault because it's unplugged - M24/3535 only). Now PO-PO & hopefully you will see a Ready To Copy screen after Power up.
    • domus electro
      The M24 works without the HDD. That is not the problem, the hdd was broken, which we replaced. question is: does the M24 itself this format and install or should it be done on a Pc?
      • TzALbg
        • Dec 2007
        • 111
        Run the HDD Diag ( ADJ 9.8). If the problem continues, replace the HDD ( PL 13.1).If the problem continues, replace the ESS PWB ( PL 13.1).
        • xcopytech
          • Aug 2006
          • 1792
          did you orded hdd from xerox or just install PC hdd?
          • Virtechs
            Do not install formatted HDD from any operating system, replace it straight away from package then do the GP3 Special Boot Mode HDD Initialization. Simultaneously press and hold 4, the Stop and the Power Save buttons on the Control panel while switching on the Power switch. Hold them down until the second circle on the screen starts to blink.
            • domus electro
              I bought a new hdd, but not at xerox. 2.5"/80gb. It is the same type so I had not expected that this gives any problems. If I do the procedure Nr.4-stop- power safe, the machine starts 2 times and after + / - 1 min it gives the same error. If I do this with the old HDD then it take 15min and I get the old error 102-372.
              So I suspect that I will need a HDD at Xerox. is this correct?
              If there is someone from belgium between, he may certainly contact me.
              • jagomez
                I Have the same problem with a Xerox DC 3535, 116-330 error.
                I Changed the HDD broken, but I don't know how run the HDD Diag (AJ9,8). I haven't the maintenance service manual.
                Any help please?
                • Virtechs
                  You can always buy new HDD from Xerox but they are very expensive. We replaced non-Xerox HDDs so many times but we did not encounter much problems. If same problem occurs even after replacing it you must have others problems. Try check the interface cable of HDD, ESS PWB, ESS NVMs, IIT/IOT cable for any defects.
                  • Milo Wilson
                    • 500
                    As long as the hard drive is same there should be no problem with putting it in. You must have another issue than the hard drive itself. You will have to load software with altboot tool if you use non Xerox HDD though.
                    • copytech200X
                      • 264
                      format hdd under low level format and turn on machine press 4 + stop +power save . Active@ Kill Disk Hard Drive Eraser. Low Level Format. freeware ..do not do any partition at windows or make it active.(just plug in to machine and press 4 +stop + power save)jot down customer network setting eg: ip,subnet and gate add before perfomed hard disk initialize.
                      • jagomez
                        I have 2 HDD units, one equal that the original a Toshiba 20GB and other Samsung 160GB.
                        I format the hdd in low level and connect to the copier, press 4+stop+powersave and report the same error code 116-330.
                        With the hdd original connected reports error code 116-201 and this hdd in windows isn't run, is broken.
                        I deduce, the hdd is broken and another device or board are broken to.
                        Any idea to check anythink? thanks
                        • copytech200X
                          • 264
                          u can try install your hdd at running condition machine and do 4+stop+power save then after "ready to copy" reinstall hdd to ur machine.
                          • jagomez
                            I don't understand, Would you say to Connect the hdd unit to the machine later power on? Is dangerous
                            The copier doesn't run without hdd, reports the same error code 116-330.
                            what steps I can do to make it?
                            • copytech200X
                              • 264
                              i mean find one running condition machine to do format ..ok
