Xerox Error 010-326
  • OsiSlave
    Xerox Error 010-326
    Xerox DocuColor 260 with error code 010-326, machine won't copy/print/scan. Any ideas?
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox Error 010-326
    Xerox DC 260 needs 220v single phase power, although it will run on 110V at reduced speeds. Turn the power off and back on several times to allow the Fuser Unit to reach the required temp. You will notice a pause in printing while the Fuser reheats.
    • adriansto
      • 2387
      Nice to know that after 4 years !
      • InterfaceP
        • Jun 2013
        • 488
        Adriansto: My post was intended for others who my have a simmilar problem now or in the future. My intent is to help. What is yours?
        • adriansto
          • 2387
          To respond in a right time.
          On Earth planet dont exist only United States.
          There are many countries with 220 volts at the power outlet and even DC242,DC252 works with 220 volts.
          As for the error code........ may be the front door interlock was faulty and that are nothing to do with power supply voltage.
