developer bearing kit
  • juanmroques
    • Jul 2025
    hello guys
    im newbe thanks you for accept me on your forum
    im from dominican republic, i have some problem with my docu12
    im changing the print drum and i need to change first the developer bearing kit to avoid drum fail again.
    do someone know how can i change this kit, some tutorial, or video or paper work to doit my self due to in my contry is very expensive to do.
    many thanks
    juan
  • WIWA
    • Mar 2009
    • 97
    Originally posted by juanmroques
    hello guys
    many thanks
    juan
    Hello Juan , I'm from Espanto Island close to you . I work on those copiers too have the whole bearing kit, als have a trick for that one. Get another ball bearing and cut the same at the gear neck a walla the same as the kit , use a dremmel to cut the gear neck for a pression cut. If some day you need help just let me know.
    Sincerely,
    WIWA 72
    Gonzos build v.1.0
    • juanmroques
      Thanks wiwa
      but where are located this bearing
      you have some schematics or instructions
      or just explain it to me how do it
      rgds
      Juan
