dcc320 hdd capacity
  • copytech200X
    • 264
    dcc320 hdd capacity
    i need replace hdd for imari original capacity "hitachi 20gb "nowadays i can't gets same capacity ..i buy new hdd 80gb but machine appears error code...i do 4stop power save also same codes appears...
  • TzALbg
    • Dec 2007
    • 111
    maybe there is file system or (and) software
    • johnner66
      • Mar 2009
      • 265
      it only take 10/20g hdd other then good luck
      • copytech200X
        • 264
        i gets info can do partition for larger size hdd ...i will test it out later reply
        • bruce fatbear
          • Oct 2009
          • 18
          a new HDD works just fine,we replace faulty HDD with a 80 Gbt,you need the PSW and run DC355 to format the new HDD.you will have to connect the ide of the HDD correctly and the process takes about 30 min.if no computer available you may borrow another working HDD.use a HDD duplicating machine to format the new HDD.but you need to clear all user's settings and key in alll new settings again.cheers
