wc-5645
  • T911
    • Jun 2007
    • 628
    wc-5645
    replace ozone filter message, is this a reset after replacement or does the ozone filter have a crum on it too. if it's just a reset would it be in nvm, copier routines. thanks t
  • xcopytech
    • Aug 2006
    • 1794
    To clear the message:
    1) Press the "Machine Status" hard button on the UI.
    2) Select "Faults" tab on UI screen.
    3) Press "All Faults" button.
    4) Select the item on the screen displaying "Replace ozone filter".
    5) The button at the top of screen labelled "instructions" now becomes active, select it.
    6) Open & close the waste toner bottle cover at left rear of machine.
    7) Press "confirm" button on UI.
    8) Message "Have you replaced the ozone filter?" will be displayed.
    9) Select the "Yes" button. This will then make the "close" button active.
    10) Select the "close" button to close the Ozone tab.
    11) Select "close" to close the "All Faults" tab.
    12) Message is now cleared.
    • T911
      • Jun 2007
      • 628
      xcopytech, thank you.
