Dcc400 Developer
  • ck1
    • 485
    Dcc400 Developer
    May i know any setting or adjustment to do after change DV or tank ? thanks
  • xcopytech
    • Aug 2006
    • 1794
    connect laptop with pws and perform dc 921
    • bruce fatbear
      • Oct 2009
      • 18
      make sure all drums ok.make sample copies before you carry out the replacement.use the old sensor from old dev. tank if still ok make note of the 2 digits number on the back of sensor [this is needed for ATC sensor adjustment (dc 921 adj.9.2) later].fix up parts,clean mirrors perform auto graduation procedure.check new sample copies.new developer have sufficient toner in it.happy troubleshooting.
