Quick Develper Install Question on DC250
  • NuBankTech
    • May 2009
    • 11
    I am installing a new Cyan Developer, the part copmes with a bag of Developer, I know this may sound like a duh questions but, do i just pop the top and pour in the new developer and screw the top on and install or do I have to mix toner in with the new developer etc. I just dont want to mess up the DC250.
    thank you.
  • Milo Wilson
    • 502
    You have to take the plastic cover off pour the developer evenly in the reseviour (sp) and turn the end gear to cycle in the dev. material.
    Put back together and should be good.
    • NuBankTech
      • May 2009
      • 11
      I did that and now I have no blue I wonder is I need to run something to get it primed or help it burn in. Have you seen this before? Thank you for your answer.
      • Milo Wilson
        • 502
        Run the dc950 setup, ATC setup. The numbers you enter are on the atc sensor on the developer assy.
        • NuBankTech
          • May 2009
          • 11
          do I have to have the PWS software or can i use the Admin GUI on the printer or something on the Creo server to run DC950, I went in to the ATC Setup and changed the number to 11 from 65, I also ran the auto grad and sadly my cyan is still really faint, sorry man I am a noob, I am a server tech playing Xerox repaitr man for an emergency job. Thanks Again for all of your help.
          • kalindd
            • Jun 2008
            • 192
            First of all can you tell us why are you installing new developer?
            The developer need to be replaced at about 1 500 000 prints. Did you had the same problem with printing blue before installing the new developer? It will be useful if you post some scans.
            What do you mean with " I don't have blue", if I'm getting you right when you try to print blue you are getting completely magenta image?
            • NuBankTech
              • May 2009
              • 11
              I had to replace the developer station, i guess it was an issue with big pale lines throughout the blue and we could find no obstructions and and we replaced drum after drum to no avail, so we had to step it up and go with teh change. I am now starting to get some Cyan when I print it's just very faint. When I am printing a solid navy it will come out as a light purple because the cyan isn't being laid down as well as the magenta. I have been looking at the settings as far as Toner density and it says the target is 599 and I am at about 351. I hope this helps a bit, it's hard to find guys in this area who actually know this machine, since we own it and don't have a xerox service contract. Thanks again for all of your help.
              • Milo Wilson
                • 502
                It obviously needs to be toned up. Run the tone up procedure through the laptop PWS
                • NuBankTech
                  • May 2009
                  • 11
                  can I run it via the printer gui, I have seen that it asks how many pages and give me the option to go + or - 99 pages. does this sound right to you, since writing I have added more developer to the unit and the cyan is getting a bit stronger. i will try the tone up/down function on the gui
                  Thanks again
                  • kalindd
                    • Jun 2008
                    • 192
                    Yes you can.
                    Taken from service manual. Hope this helps.
                    ADJ 9.3 Toner Density Setup (Tone Up/Down)
                    Purpose
                    This procedure manually increases or decreases toner concentration (TC). It is used when a
                    xerographic problem or out-of-toner condition has prevented process control from maintaining
                    the TC target value.
                    It is important that the problem that caused the low or high TC condition is resolved before performing
                    this adjustment.
                    Check
                    1. Enter the Diagnostic Mode. Refer to Entering PWS Diagnostic mode.
                    2. Select dC991 from the DC Quick menu.
                    3. Select Read.
                    4. Compare the values for ATC Measured with the values for ATC Target. If the values differ
                    by more than 25 bits for Y, M, or C; or by more than 50 bits for K, perform the Adjustment.
                    Adjustment
                    1. For each color that is above or below target, enter a value between -99 and 99 into the top
                    row. This value is the number of tone up or tone down cycles to be performed. Negative
                    values increase the ATC Measured; positive values decrease ATC Measured.
                    2. Repeat as required until ATC Measured matches ATC Target. If the measured value
                    cannot be set to the target, there is a problem in either the toner delivery system (Dispenser,
                    low toner sensor, etc.), or in the TC detection circuitry.
                    • NuBankTech
                      • May 2009
                      • 11
                      Oh this is awesome Thank you, this is exactly what i needed I can go in and adjust these now that I know they are inversely related Thank you again.
                      • kalindd
                        • Jun 2008
                        • 192
                        You are welcome.
                        Post the results.
