Doc 12 issues please have a look.
  • davidj7
    • 1107
    I have 1.5 not sure about the SP2 part
    • xFuryx
      • Oct 2009
      • 18
      Will 1.5 alone without sp2 swap them?
      • xFuryx
        • Oct 2009
        • 18
        Originally posted by AjitN
        Please check if internal test page of fiery is processed well from Fiery display. If test page gets processed but job gets drops down, your Fiery interface board is defective. I mean On fiery interface board there are two SCSI ports for print & Scan. Your Print port is bad. Only solution is to load Fiery Software V. 1.5 with SP2 ( it displays on fiery diaplay as V. 1.5 SP2) this new version actuallly swaps the port and use another port automatically for scan & Print.
        I checked it DOES get processed on the Fiery then simply dissapears!
        Where can I find Software 1.5 SP2?
        • davidj7
          • 1107
          #19
          well my friend looks like no one has the SP2,i'll send you my 1.5 CD to you , if it works well and good .send me your address
          • AjitN
            • Mar 2009
            • 287
            #20
            Please try to get V1.5 SP2. Fiery V 1.5 alone will not work as SP2 patch have capability to swap Printer port and Scanner port.
            I am sorry but I do not have CD, what I do is restore the ghost image from hard disk, which is about 6 GB in size. Wish you best lluck for getting it locally.
            • xFuryx
              • Oct 2009
              • 18
              #21
              Thanks AjitN will system software version 2 work too?
              • xcopytech
                • Aug 2006
                • 1794
                #22
                yes
                • gotoo86
                  #23
                  DC12 problem
                  the DC 12 says "turn the power to the printer ON DC12"
                  And on FieryXP12 says "Turn copier power off and on"
                  I did it a hundred times and nothing,checked cable but still not working!
                  Please help me I have a lot of job and its urgently!
                  • xcopytech
                    • Aug 2006
                    • 1794
                    #24
                    solution for your problem is posted on this site earlier.
                    search it or call a tech to fix your machine
                    • gotoo86
                      #25
                      dc12
                      I found in the searches, a little rushed I am in this post! But now I have another problem with the printer image we come without a blue color, seems to have a problem now dispenser blue
